Could anyone tell me what this component is?
Elerion
Joined Sep 11, 2017
125
Hi everyone.
I've come across a medium-small size power transformer which has a pair of components in the primary wires, which just seem like joints (but, look externally like LEDs, covered by heat-shrink sleeves).
Could anyone tell me what their role is?
Thank you!
jpanhalt
Joined Jan 18, 2008
11,087
Agree. The cord's wires are brown and green; the transformer's are blue and blue. The conversion occurs in the "item" shown. Take off the heat shrink from one and you will get a better idea. The wires are probably twisted, inserted into a ferrule, and crimped.
MaxHeadRoom
Joined Jul 18, 2013
30,808
You can also get a similar item but without the internal connector, they are similar shape but bulb shaped to cover inline crimp ring connectrs that take nut and screw fastner, this makes them easy to disconnect and are often used in motor terminal boxes where the configuration may be changed or the motor disconnected and the wires exiting the motor should not be cut to disconnect.
Max.
