Correct connections for PhotosMOS SSR
Chris Lascelles
Joined Sep 28, 2019
hi Chris,
Welcome to AAC.
Do you have a current limiting resistor on the input side of the relay module.?
E
No I did not include one. Probably fried it as has been mentioned below. I will calculate the correct value resistor and order another relay. Appreciate the help very much!
bertus
Joined Apr 5, 2008
23,041
I will take a led current of 10 mA for the calculation, as the relay needs at least 3 mA to be full on, but lower that 50 mA.
You can calculate the resistor as followed:
R = (V_supply-V_led)/I_led = (5 - 1.25) / 0.01 = 375 Ohms
A resistor of 390 Ohms Will work fine.
Bertus
