Copper Wire Issues
ben sorenson
Joined Feb 28, 2022
181
Hello, I'm playing around with different high frequency, high voltage circuits and to connect everything together I am using this extra thermostat wire I have laying around, it is easy to use as it bends very nice, and I plainly have a ton of it. The circuit does not generate a ton of heat or anything but what I am noticing is that after I experiment with the device for some hours. When I go to remove the wire it is extremely brittle and just snaps. Anyone know what could cause copper to become brittle like that? Like I said, it goes on great, turns easy and is soft to begin with so im confused....any input appreciated.
Wendy
Joined Mar 24, 2008
23,811
As the copper heats and cools down repeatedly it becomes tempered. my parents had a piece of romex going to a pump next to a pond the wire developed so much resistance that added with the pump the AC drop down to 60 volts
