Converting PC to 12-5-3.3V
camerart
Joined Feb 25, 2013
3,870
I realize that the common power supply for the "big box" PCs is quite large, and certainly there are smaller supplies available presently. But switch-mode DC supplys are one of the rather more difficult to get right. THAT is the unfortunate reality. It is also why power supply transformers are still available from most of the larger electronics parts suppliers.
The good news is that an inverter adequate to power a typical desktop computer is not that difficult.
A totally different aproach would be a used "notebook" computer that uses an external DC supply, mostly in the 17 to 23 volt range. Creating an external single voltage supply will be much less demanding.
Hi Mr B,
I'll fall back on a laptop, if this idea fails.
C
camerart
Joined Feb 25, 2013
3,870
Hi E,
If possible, measure the actual power drawn by the desktop PC, when running on mains power Usually it should be approx 100 to 200 Watts.
The current ratings shown on that posted label are typical Chinese 'enthusiastic' values.
Let's know what you measure.
E
Footnote:
Using my home Smart meter I get a value of ~100W when using a 32 Inch Monitor with a GigaByte Model Desktop PC.
That's ~0.43A, so using a 12Vdc to 240Vac Mains step up inverter 8.6A, say at 85% conversion efficiency, approx 10 Amps. A good condition 12V 60Ahr car battery would be suitable for Caravan use.
Hi E,
I ran the motherboard with only the disc drives for 1/2 hr, here are the results from a power meter.
KWh 0.020
A 0.281
WL 38.1
WH 40.2
V 237
The motorhome, will have a lifepo4 battery 12V 460Ah
and for the 3.3V I can charge a separate single lithium cell.
C.
ericgibbs
Joined Jan 29, 2010
21,649
hi E,
If that is 0.281 Amps at 237Vac, that's only ~66 Watts.
That would be only ~ 6 Amps from a 12V battery at 100% or 7 Amps at 85% conversion efficiency.
I would consider using a standard off the shelf, 12Vdc to 230Vac converter as an input to the PC.
E
this thing is that PC power draw is not fixed, it varies a lot based on application type and load. sitting idle (powered up but not doing anything) is one thing, running some application after everything is already loaded into memory is another, etc. different parts of the system are active at different teems - defragmenting HDD is a good stress test for HDD but video card load is negligible. current draw should be measured under maximum load, when everything is stressed at the same time, then add some margin to that measurement. that way you can be sure that obtained value is not exaggeration and the system will not succumb to brownouts.
camerart
Joined Feb 25, 2013
3,870
hi E,
E
Hi E,
Thinking about it, it's probably the screen, that takes most of the power use. I may use the Tv screen.
I will have a converter, probably 1000W, instead of the Maplins 300W that I already have.
This is just an experiment, as I will be getting rid of the PC, as it's too bulky, but I'll keep it if I can get it going with batteries.
C.
camerart
Joined Feb 25, 2013
3,870
Hi PM,
Yes, I'm aware of that, the figures I gave will be well under the fully working system, especially including the screen.
I doubt there will be brown outs, as the battery will cope with starting the engine.
C.
ericgibbs
Joined Jan 29, 2010
21,649
hi E,
I would say the 330W converter will be sufficient.
Ensure you have adequate fusing between the 12V battery and the Converter, and onto the Converter Output to PC input.
Why don't you set it up and try a pretest on the bench.??
E
camerart
Joined Feb 25, 2013
3,870
If this is all possible, and I don't mind a quite test/fail chuck the lot away, there are a few technical other questions.
Here is an image of the power socket on the board. There are a couple of connections that are different colours, e,g, one of them is -12V, etc, which may be a puzzle.
C
camerart
Joined Feb 25, 2013
3,870
hi E,
E
Hi E,
I've got workmen here, and I'm playing in my hobby room out of the way, and this is a little project I can try without getting in their way.
If I can figure out the pins in #38, I'll probably just cut and rejoin all of the common wires like 12V 3.3v etc, and see what happens with test batteries.
C.
ericgibbs
Joined Jan 29, 2010
21,649
hi E,
I am sure that you realise that a 12V Lithium 460Ahr is potentially hazardous if mistreated in any way.?
Mount the inline Fuse as close as possible to the battery +12V terminal, the fuse rating should be not higher than 20A.
How do you plan to recharge the Lithium battery?
E
camerart
Joined Feb 25, 2013
3,870
hi E,
E
Hi E,
Yes, these batteries are like mini bombs if treated badly!
These modern batteries have a fair bit of protection, also bluetooth and heaters inside them, and the price reflects this.
I've just put solar panels on the van, then a switch, then a fuse, then an MPPT charger, and a DC to DC charger from the alternator, with fuses. It's quite a 'to do'.
C.
C
what are the questions?
basically if you open PSU would will see that all wires of same color go to same node on the PCB. using multiple wires is simply a way to share current so that you don't have very thick single wires.
BLACK = COM/GND (0VDC)
RED = +5VDC
YELLOW = +12VDC
ORANGE = +3.3VDC
BLUE = -12VDC
then there is a standby power (low power, unlike +3.3V, +5V, +12V -12V that only turn on when PSU is on this is ALWAYS on)
PURPLE = +5VSB always on as long plugged into AC outlet. low power,
then you have signals:
GREEN = PSU_ON. this is input. when this is connected to COM (any black wire), PSU turns on and +3.3V, +5V, +12V -12V all turn on.
GRAY = PWR_OK, output tells you if power is ok.
Your measured numbers already settle most of the sizing, so work from those rather than the label on the supply.
1. Load current from the 12 V battery: you measured about 38-40 W with only the drives running. Allow roughly 80-120 W for the complete system under normal use. At 100 W, the battery current through a converter is about 100 / 12 / 0.85 = about 9.8 A, so size that branch for roughly 12-15 A continuous, not for the few amps the drives alone drew.
2. Do not connect the 12 V battery straight to the yellow +12 V wires. A charging 12 V lithium battery can sit at about 13.8-14.6 V, while the ATX +12 V tolerance is plus/minus 5 percent, or 11.4-12.6 V. Use a regulated 12 V DC-DC converter for the +12 V rail, and separate buck converters for +5 V and +3.3 V, all sharing one common ground point. Keep the red, yellow and orange wires grouped by rail, and do not mix the purple +5 VSB wire with the red +5 V rail.
3. Sequencing: the supply only turns the main rails on when the green PS_ON wire is pulled to a black ground wire, and the grey PWR_OK wire is the output that tells the board the rails are stable. Check those two signals with a meter before you connect the board: PS_ON to ground should be near 0 V when on, and PWR_OK should rise to about +5 V after the rails settle.
4. Fuse by branch, close to the battery. The 1000 W inverter is a separate branch: at full load it could draw about 1000 / 12 / 0.85 = about 98 A, so its cable and fuse must be sized for the inverter, not for the PC. The PC branch fuse should be just above its own calculated current, so a fault in the PC wiring opens its own fuse instead of relying on the much larger inverter fuse.
5. Before a long run, measure voltage at the board connector under load, not only at the converter output. Aim for less than about 0.3 V drop on the +12 V run and less than about 0.15 V on the +5 V and +3.3 V runs. If the drop is larger, shorten the run or use heavier wire for that rail first, rather than raising the converter output voltage.
Reloadron
Joined Jan 15, 2015
7,978
Pictured in post #3 is a standard ATX Power Supply, CORSAIR VS550 550 WATT PC POWER SUPPLY P/N CP-9020171 / 75-003436. My best guess is you want to power a PC using 12 VDC. They do make ATX form factor power supplies but I would do as suggested, use and inverter to get your mains voltage and then power your PSU. You will only need between 200 - 240 VAC @ 5.0 amps, I would go with 200 - 240 VAC @ 6 - 8 amps. Since your image reflects that input voltage I assume you need a 12 VDC to 200 to 240 VAC inverter.
That's how I would go about it and I would choose an inverter with a TSW (True Sine Wave) output.
Ron
camerart
Joined Feb 25, 2013
3,870
Hi all,
When designing a motorhome, volume and weight is a large factor, and everything ties into each other.
e,g, the suggestion of using a 12V-240V converter, adds the size of the converter, then in this case a PC with lots of tin and empty space plus power supply. This is what I'm considering, so if I keep the PC as it is, I would throw it away, and use a laptop. (the PC has lots of sockets for adding stuff)
Another example is gas or 12V fridge? Gas need larger bottles, 12V needs larger battery, and charging.
Thanks for all the input, once I've looked more carefully at previous answers, I'll work out all of plusses and negs.
So quick question, keeping it as minimum as possible, is it throw away PC and buy a laptop or keep the PC skeleton and buck converters? (remembering the costs)
C.
MrAl
Joined Jun 17, 2014
13,893
Hi Eric, how's things?
Here's a photo of the power supply for the board.
I don't understand 12V 42A, surely this for welding:)
Cheers, CView attachment 373330
These power supplies are made for desktop computers that have a large box either full tower or smaller tower. These sometimes include advanced graphics cards that use a lot of power themselves and can be for example 200 watts just for that.
The problem is the total power requirement means the 12v battery will most likely be stressed too much. Considering efficiency, if you had 600 watts then that would be drawing 50 amps from the 12v battery continuously. That's a big problem.
The solution is not powering the existing computer and it does not matter how long you had it. The solution is to go to a small mini computer box. These are full blow computers and you can use your existing monitor, keyboard, mouse, etc. Prices start at around $150 for the cheapest units and go up to maybe $1500 or so.
These are not partially functioning computers but full blow computers and the slightly higher end ($450) can even do gaming.
The beauty is that they have a much lower power requirement, often 50 watts or less, and even down to 10 watts, yet they function normally especially if it is to be used for business purposes. The computer I am typing this on right now is drawing about 10 watts as I type this.
This is definitely a better solution. Comparing the run times, one of these smaller boxes can run as much as 50 times longer on the 12v battery than a large desktop tower type computer with a 500 watt power supply. 500 watts for 12 minutes is 100 watt hours, 10 watts for 120 minutes is 100 watt hours. Two hours run time is a LOT longer than 12 minutes.
The other advantage is MUCH smaller size. As little as 4x4x2 inches for the case. Most of them also have more than one monitor output: either 2 or 3.
You do want to make sure you get one that can run on 12v though, and make sure it can take the full range of voltages you get from your 12v battery.
The power of these little computers goes up into the multi-core type cpus, but some of them require 19 volts input. If you get one with a 19v input you have to get a power converter that takes 12vdc and makes it 19vdc (called a boost converter). I would start with a cheaper unit and if you like it go to a more expensive unit if you want really fast processing times.
You might want to add how long you have to run the computer for in one sitting. Is it 5 minutes, 15 minutes, 30 minutes, an hour, etc.
camerart
Joined Feb 25, 2013
3,870
Hi Mr A,
This is worth looking into, while I sift through recent replies.
Thanks.
camerart
Joined Feb 25, 2013
3,870
I asked AI:
C.
For a 12V motorhome, the best computer is an efficient laptop, ideally one that charges over USB-C. It draws roughly 20-65W, runs happily from your leisure battery, and keeps working if power gets tight.
Best all-rounders
  • MacBook Air (Apple Silicon): typically 5-30W in normal use, very long battery life, and charges over USB-C. It’s the lowest-power option for general work.
  • Efficient Windows/Linux laptop with USB-C charging: thin-and-light models (Lenovo ThinkPad, Dell XPS, ASUS Zenbook and similar) with Intel Core Ultra or AMD Ryzen U/HS-series chips. Aim for something that charges at 65W or less over USB-C.
Cheap and very low power
  • Mini PC (Intel N100-class): about 10-15W, and some run directly off 12V. You’ll need a monitor and keyboard, though, so it only makes sense for a fixed desk or TV setup.
  • Chromebook: very low power and cheap, but limited if you need desktop software.
Avoid: gaming laptops and desktop towers. They draw 100-300W, which will hammer a leisure battery.
Powering it efficiently
  • Skip the 240V inverter if you can. Inverters waste power (typically 10-15% in conversion, plus idle draw), so charging directly from 12V is better.
  • A fused 12V socket with a USB-C PD (65-100W) car charger, or a wired-in USB-C PD module, charges a USB-C laptop straight from the battery. Some laptops need a 12V-to-19V DC-DC converter instead, so check your charger’s connector.
