- Joined Jan 23, 2018
- 28,332
If the camera system is for a competition car then one easy option is a set of small switches driven by the T/S lever, or possibly a link from the lever. Weight could be very small. Or even reed switches attached inside the T/S switch housing, with small wires to outside the housing. Or, if that is too complex, a latching relay triggered by the first flash, keeping the camera on until some external shutoff trigger is given. That could be very simple to implement, it could be done with small lightweight relays. and the release could even be a foot-button. And just a bit of interlock to release one when the other side was triggered. All relay logic, no complex electronics except possibly a couple diodes.Well. That is an interesting reply, as you cannot have seen my vehicle.
I have checked the circuit in my vehicle and it goes 12V to the flasher unit, up to the indicator switch, which switched the signal to either the left hand or right hand indicator lights.
I am sorry for your confusion, but my facts are correct.
I need to turn on an external video camera (think reversing camera system) when either the LH or RH indicators are energised. There is a camera on either side of the vehicle.
