So does the code in the PICAXE say that the digit 8 is defined as all LEDs lit up or does the PICAXE tell the maxim "display 8" and the maxim is already programmed to show the 8 as all leds lit up?The PICAXE does everything, the Maxim IC simply drives the 7 segment displays, since there aren't enough pins on the PICAXE to drive them. The Maxim does more than that, but essentially, the PICAXE tells it what to display, and it displays it, the "brain" is all in BASIC code on the PICAXE.
