Converting a 5v Relay to be controlled by a 12v signal input
s200bym
Joined Aug 9, 2017
82
Hi all,
I need a 5v relay but the signal input needs to be 12v. Would I be correct in saying, all I need to do is swap out the J3Y NPN for another NPN transistor that can handle 12v at the base?
Thanks,
Mike.
38,790
No.
Just add a small diode (e.g. 1N4148) from the transistors base (anode) to emitter (cathode).
But your schematic shows a PNP, not an NPN.
s200bym
Joined Aug 9, 2017
82
I appreciate your help. I managed to find another relay to try it out and it worked. I tried it on a previous relay a while back (same make and model) and the transistor got too hot to touch. It must have been a dodgy one.
Thanks.
