Convert solar LED string to DC mains
Dodgydave
Joined Jun 22, 2012
11,395
Ok understood, is there a trace/component I can break on the board to stop the charge reaching the battery terminals (now that I will have a dc supply in there instead of the battery) - Without losing the auto on/off function of the solar panel
I wouldn't bother about the solar panel trying to feed the battery terminals, it's not powerful enough to overcome the charger..
BobTPH
Joined Jun 5, 2013
11,638
Does the light have a separate light sensor for turning the lights on in darkness? Some use the solar cell for that and therefore would not work if you disconnect it.
kdn01
Joined Oct 25, 2023
6
This one just uses the voltage from the solar cell to determine day v night. Ok ill leave it as.
Thanks again everyone for their help on this!
