Convert HLT to TTL.
gregorian7
Joined Mar 6, 2018
22
Hi All,
I totally new to electronics so please be forgiving for me for my lack of knowladge.
I trying to build Labview application for my hydraulic testing. My problem is to read the signal from Flow Gear Meter due to high output voltage.
My NI hardware (counter) only to read TTL signal (up to 5V).
How difficult would be convert high voltage 24V signal to level I would be able to read on NI unit.
I attached flow meter specification. Model V2.
Dodgydave
Joined Jun 22, 2012
11,395
You can use a resistor divider network using two resistors like 19K and 5K, or any combination to give the same voltage reduction of 4.8
