conversation posts not numbered and cannot be linked.
panic mode
Joined Oct 10, 2011
5,275
some conversations happen to be rather long (many pages). as the title suggests, the problem is that those posts are not numbered. in other words there is no way to store link to individual posts. this makes it hard to keep track of things. would it be possible to make the chat threads look more like forum threads, while keeping them private?
WBahn
Joined Mar 31, 2012
33,209
In theory, yes. In practice, probably not. The necessary modifications would be at the level of the developers/maintainers of the forum software. If it is open-source (which, if it is still XenForo, it isn't), then someone from EETech with the necessary skills could do it, but I don't know that such a person exists (or, if they do, that they have the time or inclination to delve into the code base).
You might send a suggestion to XenForo. I don't know how responsive they are to feature requests.
panic mode
Joined Oct 10, 2011
5,275
Indeed . That was unexpected.
But it is an option when one is using computer. But i have not figured out how to that on other devices like on a smartphone.
Danko
Joined Nov 22, 2017
2,238
AI answer:
"To copy a word with a link on a smartphone and paste it into a text message, you'll first need to copy the link. Then, paste the link into your text message. If the link is embedded in text, you'll need to select the text containing the link, copy it, and then paste it. Finally, you may need to adjust the pasted text to remove any unnecessary surrounding text, and then send the message."
(Full answer)
BTW, "copied word" is date.
