Controlling SMPS output with digital pot
Bhargav Jani
Joined May 20, 2016
114
Hello All,
This might be bit odd but I found this discussion, and thought of asking you all
I am currently working on Switch mode Power supply IC's which will have input voltages ranging from Vbatt (12V to 48V) nominal as DC input to this IC
I wish to control the output voltage of the SMPS IC (LM25117-Q1) , either with digital POT MCP42010 with dsPIC30f4011 (as it has CAN Bus) terminal with it for communication with the other modules.
I am not fully sure if I should go ahead with designing the circuit ...
And how will I have a working connection with that of digital POTI with dsPIC4011 .
Is it good way ? or using few opamps and external circuitory going ahead with PWM will be option ?
I am not sure at this point as PCB design followed by micro-controller programming is what I have to work thereafter
thanks in advance
Dodgydave
Joined Jun 22, 2012
11,395
Your problem is the smps chip uses an Analogue input to contol the output voltage, using a two resistor divider, if you're using a digital pot the steps between each resistance may be too large for fine control.
