I searched through 200 thread topics but can't find the one I'm looking for, mind you I probably typed the wrong items in the search.
I have 12 x 140mm PC fans that I need triggered by two seperate accessories.
First entity---------------
I have one psu and I will be connecting it to this item:
http://www.ebay.ca/itm/401190616827
Which will be controlling 12 fans.
Second entity--------------
I have a humidity controller which will trigger the on/off state of this following unit which I've purchased.
http://www.ebay.ca/itm/151476448835
What I'm hoping to do is have the fans connected to both entities.
With the first entity, I'm hoping the the timer will trigger the fans on about 10 times a day keeping the air inside constantly rotating, and what I'm also hoping is that when the humidifier turns on I can also trigger those fans to turn on as well.
I'm guessing I would need a relay of sorts but I don't know what to look for.
I hope this wasn't confusing.
