Controlling an Op Amp with a DAC on Isolated Grounds
FreddieTheRobot
Joined Oct 3, 2019
Hello!
First post here, surely not the last.
I was wondering if anyone had experience driving an op amp using a Digital to analog converter that is on an isolated ground from the op amp?
See the schematic below.
My device takes in 48V DC, uses an isolated DC/DC converter to bring it down to 12VDC then again dropped to 5VDC. (I am using a PYBE20-Q48-S12 as the main DC/DC converter)
As shown above, the Op Amp is using the 48VDC input as its supply(VOLTAGE_IN), and as a result is tied to the 48V's ground(DGND_48V); while the DAC is powered via 5VDC it receives from a linear regulator connected to the the isolated DC/DC 12V output, so it is tied to the isolated ground at the output of the DC/DC. (DGND)
I'm afraid that if there are any offsets between the two isolated grounds, the device will have issues with precision. Would this be the case?
Is there anything I can do to make sure there is a static offset, or no offset at all?
Thanks,
JM
Sensacell
Joined Jun 19, 2012
3,789
As long as everything shares a common ground- no problem.
You may have noise issues relating to the CURRENTS flowing in your common ground, but that is the case regardless of your power setup.
FreddieTheRobot
Joined Oct 3, 2019
So I have been looking into that. Even though my DC/DC is "isolated" I still need to place a single point between the DC/DC input and output ground? At the input, it is called GND on the datasheet, but at the output, it is called 0V.
The 0V point is a reference and GND is ground. When laying the circuit out, the 0V reference should not carry any current.
e.g. you have a high current ground and a reference ground. They are kept separate and both are tied together at one point,
On e reason to use a current output is when your controlling a piece of equipment that requires a 0-5V signal. A resistor is placed at the equipment. The reference of the equipment is one end of the resistor.
It sometimes doesn't work for power supplies because the +output is the 0V reference for the power supply. That application requires an isolated source.
