Hello there!
I have a Panasonic FV-05-11VKSL1 bathroom Fan and trying to control it with a Lutron MA-L3T251 Maestro 300 Watt Single Pole Dimmer and Timer Switch. The timer portion is 2.5A
Fan Manual: ftp://ftp.panasonic.com/ventilation...n_0511vkl1_1115vkl1_0511vksl1_eng_install.pdf
Dimmer / Timer Manual: http://www.lutron.com/TechnicalDocumentLibrary/03092203B.pdf
The issue is that the fan has constant power; on/off functions are controlled with non-powered control wires for the control switch. In essence the on/off is accomplished by touching two wires together as in a typical analog toggle light switch.
I would like to use the Lutron timer to control the fan so I was thinking a relay would be the best option. Simply hook a the input of a relay to the switch and output to the control wires. Seems simple enough, right?
I purchased a solid state relay b/c I was thinking an electromechanical may be too loud. The relay is CRYDOM A1225 with an input range of 90-280V ~ and an output of 120V~ at 25A.
Issue is that after attaching a voltmeter to the single pole - live and timer screws on the switch i get a reading of 113V when the fan is off and 1.5V when the fan is on; so I am pretty sure the relay is not getting the right signals to close the circuit on the output end.
I would appreciate it if someone were able to point me in the right direction and either recommend a relay that would meet this application or tell me that this is not possible
Here is an image of the volt meter readouts for 4 scenarios:
HUGE thanks in advance!
K
K
