My favorite mosfet pages, he makes it so easy to understand what is hidden in data sheets.For an interesting write up see here
somebody please tell Mr. McManis about switching losses.The power that the FET is dissipating is governed by Ohm's law. The power form is simply:
P = I2R
But what's R? That would be the FET's resistance between the drain and source or Rds(on), the datasheet lists it as 5.3 milliOhms.
I think he does mention it in one of his other pages. Can you give a better real world explanation than he does?somebody please tell Mr. McManis about switching losses.
I could probably paraphrase IR’s application note AN-949 from the 1982 Hexfet data book, or the relevant section of Horowitz and Hill equally well if I wanted to.I think he does mention it in one of his other pages. Can you give a better real world explanation than he does?
Its a valid point, but switching losses are a different issue from conduction losses. Generally, at least in my experience, for a motor controller at Fsw = 10kHz, they are usually < 10% of the conduction losses so I'll cut him some slack on that. They are a much bigger issue for high-frequency switching regulators with Fsw at 50kHz up to a few MHz where they can be significant.somebody please tell Mr. McManis about switching losses.
