Control S7 1200 stepper motor
thomas29
Joined Aug 2, 2024
A stepper motor is to be controlled via an s7 1200. I haven't picked out a specific motor yet, but it will probably be a Nema 34 with maybe a gear..
My question is actually quite simple and it's about the motor driver.
I've looked at all kinds of drivers and their main supply is sometimes between 24-48 V (which my PLC supplies..)
Only the signal inputs for the pulses, i.e. left, right, one step further, etc. are always at 5V.
Do you know if there are drivers where I can connect my PTO outputs directly to the driver, or do I always have to reduce the voltage from 24V to 5V when using a PLC?
MODERATION: a commerical link that added nothing to the question was removed
MaxHeadRoom
Joined Jul 18, 2013
30,813
Stepper Motor drivers operate at a much higher voltage than the plate rated voltage, this in order to be able to maintain the plate rated voltage throughout the RPM range,
This is the motor supply, the control voltage input can be much lower.
BTW, the NEMA rating applies to the motor face dimensions only.
panic mode
Joined Oct 10, 2011
5,275
28,322
Quite often there is a rate consideration when operating a stepper motor. In those cases it is often the case that a dedicated TTL levels output module is used. With many PLC products the 24 volts I/O is not as fast.
