Contactor switching circuit
Mickmack
Joined Oct 15, 2019
6
Hi, I need a schematics drawing created.
I have 3 contactors and a 4 position switch.
Position 1 of the switch turns on contactor 1.
Position 2 turns on contactor 1 and 2
Position 3 turns on contactor 2
Position 4 turns on contactor 1 and 3
All contactors are the same voltage (230v)
shortbus
Joined Sep 30, 2009
10,050
Surely that isn't the control voltage for the contactors is it? The control voltage is the important one here not the contactor switched voltage. What type of switch is doing the control of the contactor? Rotary, toggle, or?
Mickmack
Joined Oct 15, 2019
6
The control is 24 v
And the switch is a 4 way rotary
KMoffett
Joined Dec 19, 2007
2,918
"And the switch is a 4 way rotary"
Is that one pole, four position? Break-before-Make or Make-before-Break?
If 24VDC: SP4T Break-before-Make switch, 3 cube relays and 6 steering diodes
