I'm a little confused on how a constant current supply is adequately rated for an LED panel? The LED panel seems to consist of a number of LEDs wired in series. The output current from the power supply is fixed and the output voltage is quoted between a certain range with a maximum output voltage.
I was wondering whether the same constant current power supply would work if I reduced the number of LEDs?
