A while back I created this thing, I'm not sure even what to call it. Its a 2 terminal device It's pretty much in-between a battery, capacitor and varistor.
There is a pos _ neg potential that usually floats at around 500mv - 800mv. Also there is an internal resistance of about 25- 50MO.
If I connect the pos _ neg terminals together through a 30 OHM resist and galvometer in series the voltage drops to around 300mv but there is a current of 400uA discharging and a full scale deflection.
I have tried shorting them out and or discharging them for weeks at a time an however the current never seems to drop below 300uA and the galvometer stays fully deflected.
If I interupt the circuit the voltage potential will slowly increase back to that 500mv-800mv range.
I can like a battery connect 2 in series for a higher voltage or in parallel for a higher current.
Is there anyway I can or a better way I can try to discharge them fully so they do not recover?
