To measure pulse amplitude, the PLC has to know when the pulse is present, so it can sample it. Is that something it can do?Yes I can control my measuring time in milliseconds through PLC.If so, will I be able to measure the resistance?
That sounds good. Measure the voltage as close to the weld as possible.Yes.You are right.I will design the fixture with a pneumatic pin plunged into the measuring point with source.After plunging the pins I will switch the source to ON.Through the sense pins I will read the voltage( well inside the source pins) and amplify it.I am right.
I have just built the circuit and tested it.It works fine but with some heat in the regulator IC. I have a SMPS meanwell ( 24V,2.1amps) connected to 7805 regulator IC which feeds to LM 317.
12V/24 ohms looks like a constant current source when your load is milliohms. If the weld is massively defective, it probably won't matter that the current is not constant.A constant current source has some interesting properties. Basically you are making an ohm meter (a calibrated one). If you try to use a fixed resistance then the resistance in the device under measurement (in this case the pipe) significantly affects the results, with a constant current source it doesn't.
Bill, You forgot to indicate where the current sink output is on this one.
Try the power supply leads, it's an electronic source.Bill, You forgot to indicate where the current sink output is on this one.
Bill:OK, I hadn't uploaded to the albums yet. This schematic presumes a regulated power supply, and will get hot for all the same reasons the LM317 will.
This schematic is a source, that is, it outputs the current you set it for. The other variation is a sink, which is a programable load, and looks a lot like this...
These designs work because a BJT transistor is basically a constant current device.
If you check out my blog you can get the rough library I've been working on, I like to draw concept circuits (but sometimes my concepts are flawed). Just click on the blue number next to blog entries on my post.
