Constant Current Source Stability
eetech00
Joined Jun 8, 2013
4,724
SamR
Joined Mar 19, 2019
5,535
I changed the load on the LM317L to 200kΩ and increased the Vs to 11.57V to trim the current output. Over 6.5 hours it has very slowly drifted from 50.001uA down to 49.976uA. So, increasing the load and drive added a great deal of stability! It is flitting between 49.978 - 49.980uA as I write this so appears to be going back up.
BobTPH
Joined Jun 5, 2013
11,648
Yeah I saw that on the pdf and wasn't even sure it would actually get down in the uA range but it does. This is the TO-92 cased LM317L version that only can handle 100mA max. Just not very stable and with only 1.5V driving it. But I tried and did learn something from it... I did put a 47k resistor on the output as a load and the Vs had to be 3.8V to drive 50uA but still unstable.
Which says it is not regulating at all. All you have done is adjust the voltage until you get 50uA. You could do that without the LM317.
38,814
As noted, that is not working as a current regulator, since a current regulator gives a constant-current independent of load or supply voltage, and that circuit is doing neither.
To repeat, it is not possible to use the LM317L as a 50µA current regulator.
So why are you still trying?
