constant current capacitor charge
  • Thread starter Deleted member 115935
  • Start date
Joined Dec 31, 1969
Im sorry for this,
its 45 years since I was at university, and the dv/dt thing has well left me.
I'm also mainly a Ghz high speed digital design engineer , large FPGAs and CPUs , so this analog stuff I'm not to hot at...
So I have a 1.2 F capacitor "bank" , that Im going to have to charge up from 0 to 20 volts in 3 ms ,
what constant charge current do I need ?
I'm desperate enough, I might even have to simulate this ....
Many thanks
dl324
Joined Mar 30, 2015
16,922
Are you sure you want to charge with a constant current? What is the voltage you're using?
34,452
The basic capacitor equation is C = Q/V where Q is the charge and V is the capacitor voltage.
Since the amount of charge transferred is Q = I * t where I is the current and t is the time, we can substitute to get C = It/V.
Transposing gives the solution of I = CV/t or (1.2F*20)/3ms = 8000A.
(Opps, OBW0549 beat me to it).
Joined Dec 31, 1969
Thanks for the equation,
Yep I need to work on the numbers, 8KA is a lot ,,,
but I needed the equation, so I gave some round about numbers, to get me started,
Thank you all for the very fast and detailed response,
Im sorry my analog brain could not work it out !!
Joined Dec 31, 1969
Thank you all,
with your instructions,
I have convinced the team to go for
10F , 20 Volts , but 5 seconds charge time,
which is only 20 amps, and the repeat is only once a minute, so I have time to cool down the charger.
Papabravo
Joined Feb 24, 2006
21,225
Somebody needs to slow down and double check his computations. You're fooling around with things that could have serious safety implications. Do you have any concept of how much energy is in a 10F capacitor. Have you ever seen a large capacitor explode -- with shrapnel?
Joined Dec 31, 1969
You want to see what its powering,
The main problem I had,
was I'm a digital engineer, in a world of physicists ,
and I could not convince them that we might have a problem,..
They are real experts on what they do, but some times .....
Thats why I needed your expert input,
it got them to re think things,
I'm "just" doing the digital controller,
At least they admit that designing a 52 Gb/s link is not so easy,
which I have done a few of,
even if I cant do basic maths any more,,
Thank you
AnalogKid
Joined Aug 1, 2013
11,045
Agree with Papa. 2000 W-s is nothing to play with. Be sure to check the cap datasheet for max current, max dV/dt, di/dt, etc. If that were a photographic strobe, it would be the energy for a 1 million watt flash.
ak
30,810
That is huge amount of charge. Rather than having to guess what you are doing it would help if you told us.
There are not too many things in AAC that are that TOP SECRET.
Papabravo
Joined Feb 24, 2006
21,225
Thank you
My words of caution were not meant to denigrate your talents and abilities. Once upon a time I was just the "firmware" guy. As I got more involved in embedded systems design and development, I made it my business to understand the physics of whatever I was working on for my own peace of mind and well being. My come to Jesus moment was a 100 KV power supply controller for automotive paint spray booths. As you might suspect 100 KV @50 uA will knock you into the middle of next week if you are not careful. I want you to live long and prosper.
Joined Dec 31, 1969
ak
Thank you
Now I have the experts on board where I'm at , Im much happier,
I'm keeping it secret, not only for the client, but to protect the people that made the initial decisions,
Thank you guys,
