Connecting two laptop power supplies in either series or parallel
sam68
Joined Mar 2, 2017
41
Yes, I know it is not a good idea but let's try:
I have so many extra Dells (65 and 90) and IBMs that we can fry some to test.
Some might have a sensing circuit so that might be a problem.
I think we will need a rectifier on each to make sure that if one is turned on before the other, it doesn't reverse the voltage but:
Which ones on ebay to buy (voltage and amps?)
I know very little about how to wire electronic circuits so I need help.
I bet there are a lot of people who would like to double their voltage or 2x their amps for so many projects.
35,299
Not recommended in either configuration.
You cannot connect them in series because the supplies are on common ground.
You cannot connect them in parallel because they will be fighting against each other.
tcmtech
Joined Nov 4, 2013
2,867
I use old laptop power packs like this all the time when I am in a pinch and don't have a proper sized power source near by. No big deal with anything so far.
Sensing circuit wise typically one power pack will put out a tiny bit more no load voltage but as the load current goes it it will exhibit a voltage drop allowing for the other pack to help out. Add in wiring losses with their associated cords and in parallel operation they tend to balance each other out just fine.
In series unless both have one lead of the DC side tied to a solid dedicated earth ground on the primary (three wire Vs two wire AC cord) they also have no real issues. However if they do have a dedicated earthing connection all tyou need to do is cut that connection on the power packs circuit board.
sam68
Joined Mar 2, 2017
41
Now I don't know what to do - two conflicting views.
Can others weigh in on this - have others tried it and it worked or did it fail?
Tcmtech - Did you use both series and parallel? Do you think a rectifier on both are needed? What if they don't come on at the same time?
tcmtech
Joined Nov 4, 2013
2,867
That's the difference between purists and realists views of electronics.
For purists if everything's not theoretically perfect they think it can't and thusly shouldn't be done whereas for us realists we just hook things up and see how they work and if they work don't worry about anything else until it actually becomes a problem. ;)
I just connect them as is. Everything they need to work is already in place internally so unless they have a three wire AC side power cored you can treat them just like batteries and connect them whichever way you need.
Either they work or they overload and need to be reset by unplugging them for 10 - 30 seconds.
sam68
Joined Mar 2, 2017
41
They all have a three wire AC side power cord - I didn't know that was a problem otherwise I would have mentioned it. So is that a deal breaker or is there away around it?
thanks
Dodgydave
Joined Jun 22, 2012
11,395
There is no difference in the mains leads whether it is two pin or three pin cables, it's the output voltage and current limit that makes the difference, you can connect them in parallel, but one will be taking over first, ideally use a larger current capacity single psu.
tcmtech
Joined Nov 4, 2013
2,867
thanks
It depends on whether they have a solid connection between the ground line of the cord and the DC side or not. If not no big deal but if so for series operation one or both power packs would need to have that ground connection broken.
On many of those types of power packs the DC side cord has three wires in it. Two are the power and the third one is a continuation of the ground lead from the main side power. Others however have that mains side ground tied to the DC side negative line and need to have that connection inside the power pack broken first.
AsI said before, until you hook them up and see what happens you wont know what you are working with and we are just guessing here. However at minimal thy should work fine paralleled for higher current.
sam68
Joined Mar 2, 2017
41
Since I have so many, I will try several in parallel but before I do, would it help to use a cheater plug (no third ground contact) on the AC side of one or both of them? Also, from your previous statement, am I interrupting you correctly::: if I find two of the same make and type with no third AC ground, then those would be the better ones to try and can be either parallel or series?
Rahulk70
Joined Dec 16, 2016
538
What tcmtech said about common ground will be an issue since I tried two days back to desulfate an old lead acid battery after refilling to pump in a large current and voltage 39V approx at 6.5Amps with two hp laptop adaptors from the same outlet and they had the earth pins too. the moment i connected the output pins in series one adapter always shuts down and doesnt allow me to get series voltage.The only way I could make it work was by either adding another SLA battery in series between or by using and adapter without the earth pin(2 pin plug).
tcmtech
Joined Nov 4, 2013
2,867
Yep the cheater plug on one to remove the possible solid earth connection between the two would work just fine.
Same as for the basic two prong ones. They by design typically have no earthing connection between the AC and DC sides or at least nothing that of any concern.
