Connecting a 1.5kW heating element without blade terminals
Status
Not open for further replies.
RoyRoy
Joined Feb 2, 2017
Hi I have this (rated at 1.5kW):
You can see there is no blade terminals and I don't have a spot welder to attach a blade terminal.
can I use the terminal strip insert? (ofc without the plastic casing):
I have everything else (heat rated wire and heat rated insulation big enough to contain the insert) so I am just asking about this connection. and if its safe for this application.
tcmtech
Joined Nov 4, 2013
2,867
If you remove the plastic covers then yes those types of connectors usually work rather well in moderately higher temperature applications. Especially if they are the stainless steel type.
RoyRoy
Joined Feb 2, 2017
ericgibbs
Joined Jan 29, 2010
21,568
I don't think you understand the issue, but thank you for input.
hi Roy,
I thought the issue is that you need to have a heat resistant method of connecting a hot 1.5kW heating element to the mains wiring.?
Using ceramic connectors is a common method of making this type of connection.
The ceramic connector would enable a safe, self insulated method, the option of removing the outer plastic of a regular connector would mean that the connection is exposed bare metal at mains potential and is unsafe.
Eric
It is also important to realise that the incoming mains wire will get hot at the connector and should be heat resistant/tolerant.
RoyRoy
Joined Feb 2, 2017
hi Roy,
Eric
man if I could down vote you I would.
if a mod is reading this pls lock it...
Moderator's note: Please be civil. This is apparently a misunderstanding.
ericgibbs
Joined Jan 29, 2010
21,568
hi Roy,
My reply was not done to criticise you, I was trying to be helpful.
I am genuinely sorry you have taken my suggestion the wrong way.
Can I ask what in my post has peed you off.?
Eric
LesJones
Joined Jan 8, 2017
4,543
Roy,
I can't see that any of the replies have given any wrong information.
What do you mean by your statement "I don't think you understand the issue, but thank you for input." Do you mean that you are using heating elements a dummy load ant they will not be running at their normal opperating temperature ? If so you should have made this clear.
Les.
35,170
You showed a photo of a heater element and stated it is rated at 1.5kW.
The obvious assumption is this thing is going to get very hot consuming 1.5kW.
One would assume that the feeder cable must be insulated with high temperature sleeving made of glass fibre or ceramic tubing.
What exactly is your application? How much power are you putting into the heater element?
RoyRoy
Joined Feb 2, 2017
Holy crap, you ppl can't be serious.
Answer was answered quickly and professionally by tcmtech, thanks again.
the rest of you are "trying to be helpful" by not reading the entire OP, since you didn't bother to take the time to read it, I won't waste mine to argue with you about how relevant or "helpful" your input is. Read the entire post next time.
As to moderator- question was resolved, and I requested the thread to be closed. Not sure what other productive discussion might come out of it. But after all its your call.
WBahn
Joined Mar 31, 2012
33,184
Per TS's request, the thread is being locked.
I can think of one issue that the TS might have with his proposed method if he doesn't choose his materials well. But since he isn't interested in further discussion...
Status
