Connecting 3 Li-po battery in series with BMS
Momentory
Joined Sep 4, 2022
101
I have three 2000 mAh, 3.7 V Li-po battery cells.
I want to connect these three cells in series to get 11.1 V and 2000 mah
I made 11.1 V out of three Li-ion cylinder cells before; I used a BMS.
As my project now needs a small, compact battery, I want to DIY a 3s, 11.1 V Li-po battery pack.
Can I connect the Li-po cells in series with a BMS to get 11.1 V, in the same way as with the Li-ion cells?
If yes, can I use a block adapter to recharge it?
Dodgydave
Joined Jun 22, 2012
11,395
Yes, it will work that's what they are for , if the battery pack has a built in cut off monitor, then remove it as it may not work properly.
