Connect amplifier to DFplayer mini MP3 Player
AlbertHall
Joined Jun 4, 2014
12,663
The DFplayer has a bridged output for a speaker but I need more volume. Can I connect a mono amplifier input to one of the DFplayer outputs or should I use an op-amp differential to single-ended circuit in between?
Dodgydave
Joined Jun 22, 2012
11,395
Can you not tap into the Input of the bridge amp, and put a better amplifier on it? Otherwise you're going to have to Sum the output and re amplify it.
