Confirmation of Base resistor for coil driver circuit
JulesP
Joined Dec 7, 2018
458
Hi all,
I am seeking advice on the correct configuration to power a transistor used to energise a coil inductor.
In the circuit shown the coil driver is either a FET or a BJT. With a FET the PWM signal driver is sufficient on its own to feed the coil driver Gate as hardly any current is needed to activate it and hence energise the coil. However, when using a BJT (MJE13009) to run the coil, the base current is too high for the PWM module to supply and it gets damaged. What I am proposing then is to put a 2N2222A in between the signal generator and the coil driver to boost the base current to the MJE13009 and wanted to check if I have the value of the Base resistor right. I have included all the relevant values.
This is a simple issue for someone well versed in electronics but Physics is my main subject. Any confirmation or feedback would be appreciated.
Jules
Alec_t
Joined Sep 17, 2013
15,156
Since you are using the transistors as simple switches you need them to be driven hard so that they switch on fully (saturate), otherwise they dissipate a lot of power and can overheat. Accordingly, the usual design strategy is to assign each transistor a gain of only 10. For the MJE13009 that is already marginal (the rated gain range is only 8-40 @5A), making it a poor choice here in my opinion.
With this strategy, 2A coil current implies 200mA base current in the MJE13009, hence 20mA base current in the 2N2222A.
Using a base resistor value as high as Eric suggests will not allow enough base current for the MJE13009.
You could reconfigure the two transistors as a Darlington pair.
ericgibbs
Joined Jan 29, 2010
21,571
hi,
Without the 470R the current thru the 2N2222 into the MJE Base would not be limited and it would destroy the MJE, the 10K helps the MJE to turn Off a little faster.
E
ericgibbs
Joined Jan 29, 2010
21,571
hi Jules
I misread the coil current as 200mA, not 2A, so a 47R resistor NOT 470R.
As alec points a Darlington pair would be a better option.
E
JulesP
Joined Dec 7, 2018
458
hi Jules
E
Yes it may be better overall but I have limited space left on the board and its more components so if I can make it work with the simplest I would prefer it. Assuming the gain on both BJTs is 10 then I think I need a Base resistor of 600R for the 2N2222A and 47R for the MJE.
Jules
JulesP
Joined Dec 7, 2018
458
hi,
This simulation is for 47R, using an equivalent model for the MJE .
It saturates OK, a 39R will give more Base current, but the 2N2222 dissipation is high.
E
BTW: the 47R or 39R should be at least 1.5W rating
Thanks for that. Do I need the 10k R4 between Base and Ground? Also the small blue rectangular pots that I have quite a few of, with a small brass screw on top, are they about 1.5W rating?
Julian
ericgibbs
Joined Jan 29, 2010
21,571
hi,
The purpose of the 10K is shunt to 0V any leakage current that may occur thru the 2N2222, rather than the leakage current going into the MJE Base.
It is not essential but preferable, I would certainly add it to a circuit I was building.
The small trim pots are not rated for 1.5W.
You can realise a close to 39R by using a parallel pair of say 68R, what low value resistors do you have in your bits box.?
E
JulesP
Joined Dec 7, 2018
458
hi,
E
I have 0.25W ones for 47R and the next up is 100R but I'm happy to get a few specific values at a higher rating.
28,278
The other purpose of that resistor from the base to the emitter is to assist in a more rapid switching off of the power transistor.so it is rather important. The exact value is less critical except that it must be large enough to allow adequate base drive to switch the transistor on completely.
JulesP
Joined Dec 7, 2018
458
Fair enough. Does the 600R between the square wave generator and the base of the 2N2222A also need to be 1.5W rating?
Jules
Alec_t
Joined Sep 17, 2013
15,156
Bear in mind that the stated maximum PWM source current is 15mA. That won't cope if you actually need 20mA base current in the 2N2222A.
If you're going to have to buy parts anyway, why not simply invest in a FET to switch the coil?
