concerning the black plastic spot on the pcb of display modules
walidantar
Joined Dec 21, 2019
17
concerning the black plastic spot on the pcb of display modules, in search i found it is an ic/micro-controller/interface under it, but why do manufacturers do this and not leaving it exposed like other components?IMG_0790 - Copy.JPG
jpanhalt
Joined Jan 18, 2008
11,087
That's the microcontroller. They use just the bare silicon chip and put their own epoxy over it. COB = chip on board. The related COG = chip on glass.
Reason: Cost and maybe IP protection.
Delta Prime
Joined Nov 15, 2019
1,311
chip-on-board is a chip that is wired directly to the motherboard. The chip is usually covered with a coating of epoxy or resin to protect it the way a heatsink does, as well as protecting the chips and wires from damage. This is where the term “glop-top” comes from. It is a cost-effective method of electronic packaging, but the disadvantage is that a chip cannot be replaced without desoldering, the way a socketed chip can. COBs are popular in small circuit boards because they require little physical space the way a heatsink does.
35,278
In the manufacturing process of the LCD controller board, the MCU chip is mounted directly on to the PCB.
Then the black epoxy is placed over the chip to protect it (instead of using off-the-shelf chips that are prepackaged in plastic). This is a cost saving to the manufacturer.
walidantar
Joined Dec 21, 2019
17
thanks you all, i very appreciate your response :) .. i have another question but about a different thing, do i have to put it in a new thread? i have got a 3.5mm audio connector, it's smt but has short/flush pins not pads .. how to solder it? it's cui-devices SJ-3506-SMT-TR cui_SJ-3506-SMT-TR.jpg
the pins are flush with it's bottom side, i wonder how the pcm mount will be .. is it pads? or need an connector/addapter to sit on?
ebeowulf17
Joined Aug 12, 2014
3,307
thanks you all, i very appreciate your response :) .. i have another question but about a different thing, do i have to put it in a new thread? i have got a 3.5mm audio connector, it's smt but has short/flush pins not pads .. how to solder it? it's cui-devices SJ-3506-SMT-TR View attachment 200520
Read the datasheet.
Most (reputable) parts will include a recommended "land pattern" (or PCB layout, pad layout, etc.)
jpanhalt
Joined Jan 18, 2008
11,087
this is my part (the down side to show the pins) .. on the datasheet there is nothing about the mount on the pcb
There most certainly is. Look in the lower left right side:
There you will find the recommended "pad" sizes. For real SMD, they are not that small. But for mounting sewing-needle pins, you will need to add a lot of solder.
Delta Prime
Joined Nov 15, 2019
1,311
It does say how to mount on a PCB but one must be familiar with design I'm not trying to beat you up one chooses every aspect of the components it's a matter of cost it's a matter of real estate the size of your PCB how many layers it will have the complexity the simplicity. The mere fact that if you purchased that component you should be intimately aware of why you purchased it and if not there's no rule saying that you cannot adapt it if you have the skill set. It's why I consider electronics fun I can get away with murder.
walidantar
Joined Dec 21, 2019
17
thanks you for your advice, i chosen it over the switchcraft some by fault, i saw the pins i thought it is a through hole and i can use it with a breadboard but when it arrived i realized it is a surface mount .. i didn't got aware much as should be before i buy it
jpanhalt
Joined Jan 18, 2008
11,087
If you have some prototype "stripboard" like this:
or this:
You just might be able to solder the jack you have to 0.1: 'header pins" to match 0.1" on-center bread board holes. If not, your best bet is to find a jack with a more typical (i.e., 0.1") pin spacing.
walidantar
Joined Dec 21, 2019
17
or this:
i have this, it's similar .. it tightly fits on the pads because there are two pins are very close but it works
jpanhalt
Joined Jan 18, 2008
11,087
Try it, nothing to lose. By my calculations, there was about 0.5 mm or so misalignment. Then, the holes will allow you to add 0.1" on-center pinheaders to match the breadboard perfectly.
Like this:
Very cheap and can be broken to the right length. If you need to skip a pin, no big deal.
