In AC analysis you can use any voltage level you want. It won't affect the bias point (as you probably know).I ended up using 1mv so i could read the gain directly from the voltage without disturbing the bias point too much.
Hi,In AC analysis you can use any voltage level you want. It won't affect the bias point (as you probably know).
Hi MrAl:Hi,
I ended up using 1mv so i could read the gain directly from the voltage without disturbing the bias point too much. So if the gain was 123 i would read 0.123v output which is easy to convert.
I also found that the gain of the first stage is highly dependent on the dynamic resistance of the BE diode. 0 Ohms leads to a gain of 991 while 3 Ohms leads to just 161, which is quite different. This in turn tells me the first stage should maybe be redesigned.
Hi,Hi MrAl:
I have messed around with a re-design for stage one but I have had no luck. It seems to me that the driver stage
and the input stage have very low input impedances.
aac
Hi MrAl:Hi,
Yes you have to place a resistor in series with the 470uf cap.
The 470uf cap is the main reason the input impedance is so low. It also leads to a variation in gain over some different parameters which is also not usually desirable. A series resistor helps that also because it partly swamps the rBE.
Of course we lose some gain doing that too so it's a trade-off.
Hi AG:The input impedance of Q1 and Q2 are low because the values of the base bias resistors are way too low!
Hello again,Hi MrAl:
I have done some experimentation with a series resistor.
Cap Value vout Zin Series Res
470uf 5.66 252Ω n/a
47uf 3.45 404Ω n/a
470uf 1.22 969Ω 10Ω
470uf 0.32 2KΩ 47Ω
The input resistance is too low no matter what changes I make.
I believe that the input impedance to stage 2 (Q2) is only 840Ω.
Not sure where to go from here.
aac
Hi MrAl:Hello again,
Oh i did not realize you were looking for exceptionally high input impedance.
For example when i add a 5 ohm resistor in series with the 470uf cap i get an increase from 260 to 639 ohms. I thought that would be enough as 600 ohms is a typical audio input impedance.
If you are looking for much higher input impedance then you probably have to add another stage such as an input buffer voltage follower, or add some positive feedback.
To add positive feedback, connect say a 10uf cap to the collector of Q2 with series resistor of say 300k and connect the other end of the 300k to the base of Q1. That might also raise the gain slightly. You should be able to raise the input impedance to maybe 5k ohms. However, you'll have to check for the effect this has on the distortion and that it does not oscillate. It is probably a good ideas to leave some small resistance in series with the 470uf cap too though, like 1 to 5 ohms.
I have to say though i dont really know what input impedance you are looking for, 1k, 5k, 10k, etc.
Hi,Hi MrAl:
I want to end up with a general purpose amplifier. I would like an input that would be suitable
for a microphone, tuner, cd player etc. I wasn't sure what input impedance would be appropriate
to handle those types of inputs. I also wasn't sure what output voltage those type of devices
would produce. So much to learn.
aac
thanks,Hi,
I am guessing that 600 ohms would be enough for that stuff, but i guess something could come along that needs a higher input impedance. Maybe you would be better off adding an input buffer voltage follower, which is a common collector amplifier. I would say you should be able to get at least 10 times the input impedance that way.
Note that there are some constraints on how much gain you can get vs input impedance and remember the load impedance makes that more strict because the collector resistance can not be too high in order to drive the next stage properly. It might be interesting to look at the optimum values for gain and input Z, getting the max Zin and max gain.
Just to note, here are some Zin values and Vgain values for that single stage given the second stage load is still connected and it's the original circuit with the 5.6k lower bias resistor and 988.5 ohms lower resistor in the second stage.
Zin:
[343.2716167624145,423.0930291529124,499.1176708238551,571.5336074299129,
640.556546955865,0,0,0,0,941.8798034301926]
Gain:
[131.1215728830712,103.7488718342961,85.82443677081137,73.18801492530118,
63.80460770122632,0,0,0,0,38.95380682753324]
This is for that series resistor (in series with the 470uf cap) ranging in value from 1 to 10 ohms, but i skipped 6,7,8, and 9 ohms jumped from 5 to 10 ohms that is why some are zero.
So for Rs=5 ohms, we read from the above 640.6 ohms Zin and gain of 63.8 for example.
These were all calculated from nodal analysis with re=2.7 ohms as discussed before. So if you short the 470 ohm cap the resistance on the emitter when Rs=5 is 7.7 ohms in parallel with that lower 1k.
That doesn't change the value of re4.Well, it that case you must be using the different 2N3904JP model then I use, end of the story. But nevertheless, I already show you where did you make the error in your calculations (here re4 = RE31║RL ).
What??That doesn't change the value of re4.
| Thread starter | Similar threads | Forum | Replies | Date |
Motherboard fix | Technical Repair | 0 | |
Microsofts new Quantum Computing Processor | General Science, Physics & Math | 11 | |
Computing the efficiency in LTspice | PCB Layout , EDA & Simulations | 13 | |
College of Computing | General Science, Physics & Math | 1 | |
X gate for Qutrit gate | General Science, Physics & Math | 3 |
