On the pcb it has an R designation,..its part of the current input protection on this dmm circuit, since a varistor is a voltage dependent resistor (VDR) that's my guess...??Looks like a capacitor to me. Why do you think it is a varistor?
Nope, it already has 2 ceramic fuses, 1 mA and 1A would make no sense to add a resettable fuse to the mix..Might be a self resettable fuse since you say it's located on the current input.
SG
Hmmm, why use a military grade cap on an 8$ multimeter?
That is definitely much more consistent with the application. Thanks for sharing.
There's many variables when it comes to input protection and meter robustness but the fact a vendor implemented more than a 2 cent glass fuse says alot about that manufacturer. Transients and Spikes are by there very nature highly unpredictable so by having input protection even at the most basic level it is a definate step in the right direction as far as safety implementation is concerned.Just be mindful of the following: there is a lot more to a DMM's input protection than the parts themselves. Not only the routing matters (I have seen fuses in series with the voltage jack, for example) but, depending on the nature of the event, a transient may go right through protection devices such as MOVs and GDTs without giving chance for them to react.
No question this is a step in the right direction, but it is a very different thing to assume it has decent input protection. My reply references that last statement.There's many variables when it comes to input protection and meter robustness but the fact a vendor implemented more than a 2 cent glass fuse says alot about that manufacturer. Transients and Spikes are by there very nature highly unpredictable so by having input protection even at the most basic level it is a definate step in the right direction as far as safety implementation is concerned.
I'm not assuming anythingNo question this is a step in the right direction, but it is a very different thing to assume it has decent input protection. My reply references that last statement.
Ok, that is new information. Thanks for sharing.I'm not assuming anything
It's ETL/INTERTEK Certified so the mfr is adhering to more than the usual CE aka BS protection schema/model. Impressive for a 10$ DMM.
The meter is a Mastercraft 052-0060-2, its a rebadged version of the all-SUN EM382B (OEM).Ok, that is new information. Thanks for sharing.
What meter is this? Would you mind sharing the manufacturer and model number? I don't see in this post.
