complex signal, in C/C++
sddfds
Joined Jan 9, 2022
8
hello i would like to ask how to generate the complex signal f(t)=exp^(j*omega*t), j=sqrt(-1), in C/C++. thanks very much.
Papabravo
Joined Feb 24, 2006
22,082
You define the complex data type, and use Euler's identity to compute the values in a for loop.
\( e^{j\omega t}\;=\;cos(\omega t)\;+\;jsin(\omega t) \)
If you plot this function it will be a circle centered on the origin in the complex plane. It will repeat for
\( \omega t \;=\;2n\pi,\;\text {where n is an integer} \)
click_here
Joined Sep 22, 2020
548
Just the real and imaginary numbers being printed to the screen? Or being streamed to something else?
Are you familiar with the <complex.h> and <math.h> headers in C?
sddfds
Joined Jan 9, 2022
8
the values are being sent to the arduino. i will have a look at <complex.h> and <math.h>. thanks a lot.
click_here
Joined Sep 22, 2020
548
Here is a basic example
complex example:
#include <stdio.h>
#include <math.h>
#include <complex.h>
int main(void)
    const double pi = acos(-1.0);
    for(double t = 0.0; t <= 2*pi; t += 0.01)
        double complex z = t * I;
        double complex f = cexp(z);
        printf("%.2f%+.2fi\n", creal(f), cimag(f));
    return 0;
If you really want to use 'j' instead of 'I' for the imaginary numbers, you can do this...
Code:
#undef I
#define j _Complex_I
... But be warned that i/j/k are very commonly used as iterations in for loops, so I'd advise not to do it
