AlbertHall
- Joined Jun 4, 2014
- 12,663
I suspect that you have swapped the second and third transistors so the middle transistor is 2N2222 and the the one driving the LEDs is the 2N2907.
the first circuit needs a minimum of 1.4v to turn on (2 b-e junctions);Can someone else advise why to use a PNP transistor?
I removed the second 2N2222 and checked the legs with my multimeter diode function (positive lead on base, negative leads on collector or emitter) and the reading was O.L for both whereas it was ~0.7 V for an unused 2N2222. I put the functioning 2N2222 in place of the defective 2N2222 and took new readings. Something is still wrong because the LEDs do not illuminate and my power supply reports an output of ~200 mA. The expected output is ~20 mA. Various components of the circuit get warm so I kept the circuit connected only long enough to take each reading.The 2N2907 may be fried. You are pushing nearly 15mA through its base. You could increase its base resistor to at least 10K (likewise for the first 2N2222).
If the second 2N2222 has a Vbe of 6.3V then that transistor is either dead or has a bad connection.
I thought the same but (unfortunately, because I'd be done now if this was the problem!) I've confirmed twice that all the transistors are in the correct locations.I suspect that you have swapped the second and third transistors so the middle transistor is 2N2222 and the the one driving the LEDs is the 2N2907.
