Actually because it is a homework, we are not supposed to heat or cool the whole actual environment. Our aim is to make LM35 measure the ambient temp we wants to be only, I mean the room does not have to be at the temperature the LM35 measures. Therefore we can and will place cooler and heater very close to LM35 so I think BD135 will be enough. And unfortunately Mosfet is forbidden to use according to rules of this homework.While you're pondering that, let's nail down how you will switch your loads. You mentioned using BD135 transistors. Those can handle a max current of 1.5A (per the data sheet) but realistically shouldn't be used for any load over 1A or so, and will need heat sinking for that.
Is that enough for your heater or fan?
Your BD135 is a BJT and requires a base current of about 5-10% of the load current, in order to be fully turned on. Can you get that much current to it? I'm hinting that you may want to consider a MOSFET. It can switch a large load with a tiny control signal (voltage, not current) and probably won't need a heat sink.
Let me explain the way the circuit is supposed to work. First of all, circuit checks if the ambient temp is equal to the desired temp, if it is, neither cooler nor heater works. If it is different than the desired temp, then circuit starts to work to bring the ambient temp to the desired temp. When the desired temp is reached, both cooler and heater stops. Then, if the ambient temperature increase above the desired temp more than 2 degrees, the fan works until the desired temp is reached and when the desired temp is reached, fan stops. Similarly, if the ambient temp decrease below the desired temp more than 2 degrees, the heater starts to work till the desired temp is reached. When the desired temo is reached, heater stops.As you have described things, you are setting up conflicting requirements. If the temperature is one degree above the desired temperature, should the fan be on or off?
Do you see what I am talking about? If the temperature is above the desired temp by 1 degree C, you can't answer the question of whether the fan should be on or off. You need additional information. Well, if YOU need additional information, then your circuit needs additional information, too. This is most easily done by introducing hysteresis. So you need to read up at least a bit about what hysteresis is and how it is used to do what you want to do. Then we are in a better position to discuss ways to implement a circuit that has the hysteresis you need.Let me explain the way the circuit is supposed to work. First of all, circuit checks if the ambient temp is equal to the desired temp, if it is, neither cooler nor heater works. If it is different than the desired temp, then circuit starts to work to bring the ambient temp to the desired temp. When the desired temp is reached, both cooler and heater stops. Then, if the ambient temperature increase above the desired temp more than 2 degrees, the fan works until the desired temp is reached and when the desired temp is reached, fan stops. Similarly, if the ambient temp decrease below the desired temp more than 2 degrees, the heater starts to work till the desired temp is reached. When the desired temo is reached, heater stops.
Simply, circuit makes ambient temp equals to the desired temp first. Then both heater and cooler stops. If the ambient temp exits the +2C' -2C' interval, simultaneously the heater or cooler starts to work until the desired temp is reached.
How is that different from what it does outside the ±2°C interval?If the ambient temp exits the +2C' -2C' interval, simultaneously the heater or cooler starts to work until the desired temp is reached.
If the ambient temp is at outside the interval, then heater or cooler works till desired temp is reached. After reaching the desired temp, neither heater nor cooler works as long as the ambient temp is inside the interval. When it got out the interval, again the heater or cooler starts to work till desired temp is reached. And it keeps going like this.How is that different from what it does outside the ±2°C interval?![]()
Thank youDo you see what I am talking about? If the temperature is above the desired temp by 1 degree C, you can't answer the question of whether the fan should be on or off. You need additional information. Well, if YOU need additional information, then your circuit needs additional information, too. This is most easily done by introducing hysteresis. So you need to read up at least a bit about what hysteresis is and how it is used to do what you want to do. Then we are in a better position to discuss ways to implement a circuit that has the hysteresis you need.
It doesn't matter how near your loads are. What matters is the current draw, which you have not specified. I'm trying to warn you that your transistor controlled by the comparator output might not be able to control more than 100mA or so, and this may not be enough to run your loads.Therefore we can and will place cooler and heater very close to LM35 so I think BD135 will be enough. And unfortunately Mosfet is forbidden to use according to rules of this homework.
Then you just need the heater to come on when the temperature is more than 2°C below the desired value, and turn on the fan when it is more than 2°C above the desired value.If the ambient temp is at outside the interval, then heater or cooler works till desired temp is reached. After reaching the desired temp, neither heater nor cooler works as long as the ambient temp is inside the interval. When it got out the interval, again the heater or cooler starts to work till desired temp is reached. And it keeps going like this.
The problem is that it will not meet his specs. If the temperature is more than 2°C above the set point, his specs require the fan to come AND REMAIN ON until the temperate REACHES the set point (i.e., "till the desired temp is reached"). It is only AFTER the desired temperature is actually reached that the system goes into an idle mode pending an excursion outside the ±2°C limits.Then you just need the heater to come on when the temperature is more than 2°C below the desired value, and turn on the fan when it is more than 2°C above the desired value.
What problem is there with doing that?
Okay.The problem is that it will not meet his specs. If the temperature is more than 2°C above the set point, his specs require the fan to come AND REMAIN ON until the temperate REACHES the set point (i.e., "till the desired temp is reached"). It is only AFTER the desired temperature is actually reached that the system goes into an idle mode pending an excursion outside the ±2°C limits.
Close. I think you just have a couple typos and meant "2 degrees" in both places where you have "1 degree".Okay.
So now I understand the need for hysteresis in the set point.
Thus the fan turns on if it goes 1 degree above the set-point and back off when it reaches the set point.
And the heater goes on if it goes 1 degree below the set-point and off when it again reaches the set point.
That sound right?
Right.Close. I think you just have a couple typos and meant "2 degrees" in both places where you have "1 degree".
I think the accuracy is generally better than that within "normal" ambient ranges, and the precision is quite a bit better. It's all in the data sheet, which I haven't looked at for a long time.LM35 has how big an error? +/- 1 °C?
You are right.That's my read of it also. This means to me there is chance of both loads being on at the same time if there
| H | ambient temperature problem | General Electronics Chat | 100 |
| Similar threads |
