Communication Protocol between a fuel dispenser and a Microcontroller
Sunnex0
Joined Apr 25, 2019
Good day guys,
I am currently working on a project where I need to get data from a fuel dispenser.
Due to the fact that it is not feasible for me to access a fuel dispenser , I am stock on get which communication
medium I can use to fetch data from the fuel dispenser to my microcontroller( Arduino, Raspberry,etc).
Please I really need on this.
Thank you
shteii01
Joined Feb 19, 2010
4,644
Good day guys,
Thank you
Um... that information came from fuel dispenser. You know what it is. You know the model. You know the manufacturer. Go and dig it out.
Asking here is waste of time since we don't know anything about YOUR fuel dispenser.
Sunnex0
Joined Apr 25, 2019
Does the communication medium differ from each fuel dispenser?
WBahn
Joined Mar 31, 2012
32,951
Probably not from each fuel dispenser, but it's pretty much guaranteed that not all fuel dispensers use the same communications protocol.
You need to get the specific information for the specific make/model of dispenser you will be interfacing to.
Sunnex0
Joined Apr 25, 2019
While I get the spec of the fuel dispenser, please what are the common communication medium for most dispenser ?
WBahn
Joined Mar 31, 2012
32,951
I have absolutely no idea -- and it really doesn't matter, does it? If 99.9% of fuel dispensers use Protocol 99X but the fuel dispenser you need to interface to uses Protocol 42Z, then knowing that the rest of the world uses 99X does you no good whatsoever.
