Communication between Arduino and RPi Zero
Croduino4647
Joined Mar 3, 2021
8
Hi!
I have to connect servo motor on Arduino and control it via RPi Zero. Which is the easiest way to make a communication between RPi and Arduino.
Ty!
LesJones
Joined Jan 8, 2017
4,544
I think you need to give details of your servo motor. Is it a model type servo whose position is defined by the duration of the pulse ? Or is it a motor with some kind of position encoder and the two computers close the feedback loop ? What exactly are you trying to achieve ? The more information that you supply the more likely we are to solve your problem.
Les.
