Communication between RPI Zero & Arduino Nano
OrSimhon
Joined Dec 13, 2019
5
Hello ,
I am asking before i will start to work on my project.
I need to use little Camera and OpenCv to detect simple obstacles , and as a results to navigate robot.
I thought to use RPI Zero for analyze the obstacle and to use Arduino Nano to operate the robot motors.
i need that all of this to be a miniature as possible.
RPI Zero can communicate with an Arduino nano ?
Someone have another idea to offer me ?
trebla
Joined Jun 29, 2019
599
You can use serial connection between RPI and Arduino. But be aware that RPI operates at 3.3V level and Arduino Nano operates at 5V level. That means you must use a level converter circuitry or be very careful not to use any pull-ups on Arduino side (if it operates as I2C slave).
KoaG
Joined Dec 8, 2015
10
The most simplest solution - connect nano to rpi zero using a micro to mini usb connector, with this you can directly send commands to nano using pyserial library.
