Commonly used acronyms and synonyms in electronics
Ian0
Joined Aug 7, 2020
13,311
Since I've been on this forum the only acronym that completely flummoxed me was "MOT".
MOTTC_1_Q_300-500x500.gif.. . . but I don't think that this is what the person who mentioned it was intending.
Reloadron
Joined Jan 15, 2015
7,977
Electronics is a field filled with acronyms and synonyms to describe components, processes, and technologies. Here are some commonly used acronyms and synonyms in electronics:
  1. AC- Alternating Current
    • Synonym: AC power, AC voltage
  2. DC- Direct Current
    • Synonym: DC power, DC voltage
  3. LED- Light Emitting Diode
    • Synonym: LED light, LED indicator
  4. LCD- Liquid Crystal Display
    • Synonym: LCD screen, Liquid Crystal Panel
  5. OLED- Organic Light Emitting Diode
    • Synonym: OLED display, Organic LED
  6. CPU- Central Processing Unit
    • Synonym: Processor, Microprocessor
  7. RAM- Random Access Memory
    • Synonym: Memory, Main Memory
  8. ROM- Read-Only Memory
    • Synonym: Firmware, Permanent Memory
  9. USB- Universal Serial Bus
    • Synonym: USB port, USB connector
  10. PCB- Printed Circuit Board
    • Synonym: Circuit board, Board
  11. IC- Integrated Circuit
    • Synonym: Chip, Microchip
  12. RFID- Radio-Frequency Identification
    • Synonym: RFID tag, RFID technology
  13. NFC- Near-Field Communication
    • Synonym: NFC technology, Contactless communication
  14. WIFI- Wireless Fidelity
    • Synonym: Wireless network, Wi-Fi connection
  15. Bluetooth
    • Synonym: Bluetooth technology, Wireless data transfer
  16. GPS- Global Positioning System
    • Synonym: GPS navigation, Satellite navigation
  17. Amp- Amplifier
    • Synonym: Amplification device, Audio amplifier
  18. Volts- Voltage
    • Synonym: Voltage level, Electric potential
  19. Ohms- Resistance
    • Synonym: Resistance value, Electrical impedance
  20. FET- Field-Effect Transistor
    • Synonym: FET transistor, Field transistor
  21. MOSFET- Metal-Oxide-Semiconductor Field-Effect Transistor
    • Synonym: MOSFET transistor, MOS transistor
  22. CPU- Clock Processing Unit (when referring to a clock signal generator)
    • Synonym: Clock generator, Clock circuit
  23. PSU- Power Supply Unit
    • Synonym: Power source, Power adapter
  24. SMT- Surface Mount Technology
    • Synonym: Surface mount assembly, SMT components
  25. DIP- Dual In-line Package
    • Synonym: DIP package, DIP IC
  26. EEPROM- Electrically Erasable Programmable Read-Only Memory
    • Synonym: EEPROM memory, Flash memory
  27. ADC- Analog-to-Digital Converter
    • Synonym: A/D converter, Analog-to-digital chip
  28. DAC- Digital-to-Analog Converter
    • Synonym: D/A converter, Digital-to-analog chip
These acronyms and synonyms are just a fraction of the terminology used in electronics. The field is constantly evolving, and new technologies and terms emerge regularly, so staying up-to-date is essential for professionals and enthusiasts in the industry.
How many of those were around 40 ~ 50 years ago? :) It's a changing field.
Ron
28,525
Many were around back then, but many were not even concepts. But in 1973 we already had computers and a/d as well as D/A converters Also DIPs and PROMs. No SMDs as we know them, but there were some interesting schemes for automated assembly. The biggest difference then was that a fair amount of consumer electronics was considered worth repairing, and so there were repair shops that actually could repair things.
Lundwall_Paul
Joined Oct 18, 2011
236
I remember in the 60's CD meant Civil Defense, then Certificate of Deposit, Change Directory, Compact Disk...
jiggermole
Joined Jul 29, 2016
188
Not too many are familiar with Pyrotanex cable or even ever worked with it.
Tubular Copper with conductors embedded in a insulating fireproof mineral '
Used in fire proof required situations, alarms, sprinklers etc
In the Navy they use similar type. It had steel braid on the outside and was filled with the mineral insulation like you said. Would periodically open a panel and the insulation had oozed making a mess in the box.
MaxHeadRoom
Joined Jul 18, 2013
30,881
PyroTanex was/is imbedded in hard magnesium oxide material.
Ian0
Joined Aug 7, 2020
13,311
Working with it is a skill that is dying out.
Before long there will be demonstrations of it at country fairs along with thatching and basket-weaving.
28,525
Anyone remember NTSC? AKA Never The Same Color Twice
Please consider, though, that adding color to a monochrome signal that remained workable, compatible with both, and doing it with vacuum tubes, was an incredible achievement.
Consider that digital TV benefits only the sellers and the broadcasters, and in one motion created a huge amount of E-Waste, as it is totally incompatible. In that one change they made every TV produced since 1950 obsolete. And for what benefit?? The quality of the programming is still down in the sewer, for the most part.
Ya’akov
Joined Jan 27, 2019
10,357
And PCMCIA
(People Cannot Memorise Computer Industry Acronyms)
Somewhere I have a real PCMCIA 1MB card with battery backup (that is, not non-volatile). I got it from the PCMCIA at Comdex in Las Vegas in 1990, it was a prototype and the only thing that (currently) worked in my shiny new PCMCIA slot.
So, why was the expansion of PCMCIA so hard to remember? Because it was a terrible choice for the purpose. It means “Personal Computer Memory Card Industry Association”. Why would the call the hardware that?
It also very rapidly came into use for anything but memory cards.
28,525
Certainly, "Y", and it is interesting how some creations are widely used for other than the intended purpose. the two that seem most used are USB, now utilized as a power plug, and POE (Power Over Ethernet) now being used for computer controlled lighting installations because it does not require the high-priced electrical workers. ( just wait until hackers discover how to switch off all the lights.)
Ian0
Joined Aug 7, 2020
13,311
I have to mention LASER (Light Amplification by Stimulated Emission of Radiation) because it's not an amplifier, it's an oscillator, so it should be a LOSER.
