So I started tinkering with arduino a couple of years ago. My background in electronics is that of a noob with a little hands on experience and little theory.
I've worked with 2 circuits that I tried to assemble following tutorials but failed miserably:
1. Amplifier using lm324 opamos all while only learning how opamps work. I sorta grasped the understanding but decided to move on.
2. Oscillator circuit using 3906 & 2222 transistors, resistors and capacitors. Originally the idea was to make a led flash on and off to keep a battery pack alive. Again I sorta got a grasp on how the circuit should work but couldn't get it working.
So I can sorta see how oscillator circuits and amplification circuits are common. Today I cracked open a solar mobile charger consisting of a solar panel, nine 18650 batteries and some circuitry.
Among the circuitry is a small strip board which I've seen in other mobile chargers which I believe is used to regulate the charging process. Here is the image below. Can someone explain in as layman terms as possible how it works and gradually move into the details?
