I am working on a colpitt oscillator circuit which looks like this.
The tank circuit is completed by attaching an inductor coil to it. The inductance of the coil ranges in micro Henry. The aim is to find the inductance of the coil, through the frequency generated by the tank. I am measuring the frequency from the freq_out terminal. Everything works fine but I had a thought of finding inductance of more than one coil using the same circuit. To implement this, I have to somehow 'break' the connection of one tank circuit, temporarily, and 'make' connection with another (poposed) tank circuit. This ensures that one tank won't influence the other. But here comes the problem.
As both the start and end terminal of the tank (c_out to c1 and c2 to c_in), contains oscillation, I couldn't make a switch there using a device like a transistor. But the terminal between C1 and C2, contributes to potential difference (It provides the base of the transistor with the potential difference of C2), which can be switched using a transistor. I did this succesfully, and I am able to have two tank circuits parallel to each other. But both have influence over the other.
I thought of providing some kind of temporary isolation, which failed. I did some research but couldn't find anything interesting. The problem is, I have to isolate atleast one end of the tank, so that I can switch between two tanks within a small delay, and obtain different frequency values. Any suggestions?
