MisterBill2
- Joined Jan 23, 2018
- 28,509
I suggest an experiment of leaving the diodes off and seeing how many operations it takes to cause any visible damage to some contacts. Just wire a relay with the coil in series with the normally closed contacts and then power it with the specified coil voltage. This will be a worst case situation because the coil current will be interrupted before the contacts fully open. It will be a classic buzzer circuit. It will also be rather educational.
