Coca cola Koolatron mini cooler Item# KWC-4 will not turn on
JeffPola
Joined Oct 15, 2018
Hi folks,
I need some help figuring out the problem with my daughters small coca cola mini cooler.
When plugged in using the 125V power cord it came with and I slide the on switch to the cold or hot position nothing happens.
The hot or cold LED light (whichever position I switch it to) will blink for light a half second and that's it, the fan will not start. It's like there is no power going to the device.
I then tried it in my truck using its 12V plug ... and it turned on immediately.
Any suggestions on what could be wrong with it?
Thanks,
Reloadron
Joined Jan 15, 2015
7,943
Really your best bet would be to contact Koolatron using the Contact Us link on their website. Less a good schematic all we can do is speculate. Since the unit does work on your 12 VDC truck power but does not work on 120 VAC mains power the logical guess is the unit has an internal 120 VAC to 12 VDC supply which likely is not working. Now how they do that is likely using a SMPS (Switch Mode Power Supply) but again, less a schematic or drawing it is all pure speculation.
Ron
Reloadron
Joined Jan 15, 2015
7,943
My guess is the smpsu is duff,or fuse blown inside, take the back off and post pictures of the inside..
I thought about the fuse possibility but sort of discounted it because the cold/hot LED momentarily illuminates. Yeah, won't hurt to try and gently open it up and look for anything obvious and post some images.
Ron
AlbertHall
Joined Jun 4, 2014
12,653
Ron
It sounds like an SMPS starting up, then being shut down because it discovers a problem - a typical fault condition.
Dodgydave
Joined Jun 22, 2012
11,395
Yep classic switchmode psu there, output on the left side with the blue electrolytic caps.
What's the big heatsink above it with yellow wires, peltier?
Need to measure the Voltages .
ArakelTheDragon
Joined Nov 18, 2016
1,366
A capacitor may be the problem, another smaller chance option: you can try pluging it to a different electrical grid connector in a different room, which is not on the same circuit braker.
