COB LED lighting and 9 volt battery
Josh74
Joined Apr 21, 2017
Hi all
I need to make a lighting ring using a COB LED. The lighting must be bright and also last for a 5 hour period. What would you recommend as I can only use a 9V battery due to limited size of housing.
I have limited space of 48mm for the ring, and need a 20mm center clearance for a camera lens.
Thanks in advance
Dodgydave
Joined Jun 22, 2012
11,395
Then first select the leds that you want, noting their current drain, then select a battery with a Ampere hour rating that will give you that, you may find you will go for lithium-ion or nickel.
So example leds take 300mA, for 5hours, that's a 1500mAh battery minimum.
Josh74
Joined Apr 21, 2017
Many thanks can you get a lithium battery as small as a 9 Volt?
Dodgydave
Joined Jun 22, 2012
11,395
Do you mean Physical Size, like a PP3?
At best a PP3 will be 850mAh, you're better going for the 18650 cells or lifepo battery.
