CMOS - TTL comparison + datasheet assistance
Random3s
Joined Jul 30, 2014
38
Hi all,
I am currently completing a report comparing CMOS and TTL IC's. I am comparing a hex inverter IC, and need some assistance locating the output current (both high and low), of the CMOS hex inverter (CD74HC04).
I understand there is a max amount of current a device can sink or source whilst still maintaining a high or low logic level, so generally a max source/sink current is designated per output pin....
The datasheet is located here and I am comparing the CD74HC04 model (CMOS load only).
I can see the max rating state:
DC Output Source or Sink Current per Output Pin, IO
For VO > -0.5V or VO < VCC + 0.5V . = .±25mA
So as long as Vo is between than -0.5v and Vcc +0.5 the output pin is able to source and sink ±25mA per output?? So the high level output voltage for CMOS loads is 0.02A... meaning that the normal operating specs, output current is generally around 20mA per output pin?
Id appreciate a shove in the right direction
Thanks
38,533
Close. The table states that for the particular Vcc supply voltages of 2V, 4.5V, and 6V, the output will source or sink 20mA when the output voltage is within (Vcc-0.1V) or within 0.1V of ground.
RamaD
Joined Dec 4, 2009
328
In 74HC series, the CD series from TI (earlier with Harris) have better drive currents of the order of 25mA. Whereas the M74HC from ST, MM74HC from Fairchild, SN74HC from Ti, are all much lower, approximately 5mA source/sink for about 0.5V drop, varying between makes! That way CD74HC series may not be a true representation of 74HC series.
Random3s
Joined Jul 30, 2014
38
Thats good information, thanks.
I am comparing the 74LS04 I can see that it has a Iil of 0.4ma compared with the CD74HC04 which has an Iil of 0.02ma....
Random3s
Joined Jul 30, 2014
38
I am still a little confused by this to be honest. As I read the data sheet, the .02mA figure is purely a test condition. As only an absolute maximum is provided on the data sheet are we to presume that the outputs can handle a max of 25mA, but we should be aiming at lower than this in order to avoid damaging the IC?
For VO > -0.5V or VO < VCC + 0.5V . . . . . . . . . . . . . . . . . . . .±25mA
Jony130
Joined Feb 17, 2009
5,598
The large the output current(Ioh) the large the voltage droop across MOS. And this will reduce Voh voltage.
And if Voh drops below Vih, the next gate will not properly recognize a high state at his inputs.
