CMOS OR gate
AD633
Joined Jun 22, 2013
96
Hi,could someone confirm someone could confirm whether my analysis of this circuit that implements an or gate with cmos is correct?
I find it a little confusing that the output is extracted from that point.
For the output to be equal to 1(high state) Q5 will always have to be on,right?
I mean is not possible the output to be 1 if Q5 is off and Q6 is on rigth?
Input A Input B
0 0
Q1 ON,Q2 OFF,Q3 OFF,Q4 OFF,Q5 OFF ,Q6 ON
Output = 0
Input A Input B
0 1
Q1 ON,Q2 ON,Q3 OFF,Q4 ON,Q5 ON ,Q6 ON
Output = 1
Input A Input B
1 0
Q1 OFF,Q2 OFF,Q3 OFF,Q4 ON,Q5 OFF ,Q6 OFF
Output = 0 (this is not correct ,since this is a or gate.The state of Q5 will determine wheater the ouput is 1 or 0.Q5 depends on the state of Q2 and Q3.So if Q2 is off and Q3 is ON this means that Q5 will be on?It is not necessary that Q2 is ON in order to Q5 be on to?
Input A Input B
1 0
Output = 0 -->same situation as for the previous situation
Q1 OFF,Q2 OFF,Q3 O3 ON,Q4 ON,Q5 OFF ,Q6 OFF
Thanks
33,204
Why do you find it confusing? We need something more than that if we are going to try to clear up the confusion.
Correct.
Correct.
Input A Input B
0 0
If Input A being 0 results in Q1 being ON, then why would Input B being 0 result in Q2 being OFF. Does that make sense?
If Q1 is the only transistor (out of Q1 to Q4) that is ON, then how can any signal get to the gates of Q5/Q6?
For a digital CMOS circuit, functionally you treat a PMOS as ON if the gate voltage is LO and an NMOS as ON if the gate voltage is HI. But you have to have a path from the gate to a driving source (an input or a supply) that goes through gates that are ON.
AD633
Joined Jun 22, 2013
96
It consfuses me that the output is extracted from the drains two transistors.If the transistor Q5 is on it will have current in the drain.And if only Q6 is on we dont have current in the drain?The output is not high because we don't have a path from the gate to a driving source (an input or a supply) that goes through gates that are ON(in the case i mentioned Q6),when Q5 is OFF?
So if i have 0 0 in the input
Q1 ON-->Vgs<0
Q2 ON --> Vgs <0
Q3 OFF
Q4 OFF
Q5 OFF
Q6 ON--> Vgs>0
Input A Input B
0 1
Output = 1
Input A Input B
1 0
Q1 OFF
Q2 ON
Q3 ON
Q4 OFF,
Q5 OFF because Vgs=0v
Q6 ON
So if Q2 is ON and Q3 is ON this means that Q5 this means that Q5 will have +Vdd on the gate and on the source.Theferore Vgs=0V,so i dont understand how Q5 can be ON(since it will have to be because the circuit implements a OR gate).
Thanks
Good way to remember it is ...
OR (any 1 Gives a 1)
AND (all 1s give a 1)
Nand (all 0s gives a 1)
When you formally study this, this is how they teach it.
Write it out on paper 100 times and you never forget.
AD633
Joined Jun 22, 2013
96
My question isnt't about that.What i want to know is how can transistor Q5 be ON when we have
Input A Input B
1 0
If Q2 is ON and Q3 is ON this means that Q5 this means will have +Vdd on the gate and on the source.
Sorry I read things quick and in part and make assumptions sometimes. I am on a smart phone too.
Your question is rather complex, and I do not have answers off the top of my head. Perhaps an expert or two can shed some light?
AD633
Joined Jun 22, 2013
96
who said current!? MOSFETs are voltage-controlled devices.
What is Vds for a saturated MOSFET?
Vds=Vgs-Vt,the n-channel pinches off at the drain and therefore there is no current at the drain?So this means that there is no current at the drain when the MOSFET is saturated?
Thanks
tshuck
Joined Oct 18, 2012
3,534
Thanks
Why are you concerning yourself with current? We are talking about what happens in a voltage-controlled device, however, there will be almost no current, aside from switching currents...
AD633
Joined Jun 22, 2013
96
Why is Q5 pulled to the ground?Q2 is off and therefore it isn't possible to have +Vdd in the gate of Q5,but how do i know is the gate of Q5 is conected to the ground?Because Q3 is ON and it creates a path to the ground for Q5 is that it?
Thanks
tshuck
Joined Oct 18, 2012
3,534
Thanks
Vds for a saturated transistor is ~= 0V... Vds for a transistor in cutoff is unbound...
tshuck
Joined Oct 18, 2012
3,534
So vds of Q3 is aprox 0 V and therefore since Q3 is ON there is path that conect the GATE of Q5 to the ground,rigth?
allow me to rearrange your statement:
So, since Q3 is ON(and in saturation), Vds of Q3 is aprox 0V, therefore the GATE of Q5 is aprox 0V, with respect to ground.
AD633
Joined Jun 22, 2013
96
What if the inputs are both equal to 1
Input A Input B
1 1
Output = 1
Q1 OFF,Q2 OFF,Q3 O3 ON,Q4 ON,Q5 ON ,Q6 OFF.Is that it ?
Thanks
tshuck
Joined Oct 18, 2012
3,534
Input A Input B
1 1
Output = 1
Thanks
Sounds like you've got it...however, you should learn to put your information into tables, it would help others know what you are attempting to say...
