CMOS OR gate with low pass filter
Papabravo
Joined Feb 24, 2006
22,111
The reason why has to do with the transition time of the input signal. The longer the rise time or fall time of the signal the more time the gate is in the linear region effectively shorting the power supply to ground at the output.
karas
Joined Sep 8, 2011
216
Slowly transition edges (signals) increase the time that both output transistors are on.
Thanks, do you mean increasing the linear region, because it can be on some time and off some times, so the problem in the linear region where the switch has voltage and current so the dissipation is high and it can blow the device.
is what i understand is right ?
dl324
Joined Mar 30, 2015
18,454
That's the basic idea. There's a maximum power dissipation figure for all devices in a package. So it's okay to operate in the linear region as long as you keep power dissipation under the allowed limit.
Inverting gates can be biased in the linear region and be used as amplifiers.
38,755
Another problem with a slow rise/fall time at the gate input is that it can oscillate in the linear region due to stray capacitive feedback.
You can use a low-pass filter at the input if you use a Schmitt-trigger device such as the CD4093, CD4106, CD4583, CD4584, or CD4106, as they will give a sharp transition at the output no matter how slowly the input changes.
There should be equivalents in the 74HC series.
Here's a list of 74x devices. Look for those with a Schmitt-trigger input.
karas
Joined Sep 8, 2011
216
Thanks so much, do you the maximum input capacitance i can use it with this part
https://media.digikey.com/pdf/Data Sheets/ST Microelectronics PDFS/M74HC4075.pdf
karas
Joined Sep 8, 2011
216
Papabravo
Joined Feb 24, 2006
22,111
Thanks so much , can you please explain more(how the power supply get shorted at the output)
Sure. The totem-pole output has a p-channel FET and an n-channel FET. The output is where the two FETS are connected together. When the input is in the transition region about Vdd/2 both FETS are in the on-state and a substantial current begins to flow. The longer the transition lasts, the more time the "short" has to generate heat. Enough heat will kill a part. That is also why CMOS inputs must never be left floating.
38,755
Thanks so much , can you help me to figure the maximum capacitance i can use it for this part
You don't want use a capacitor with that part.
You need to use one with a Schmitt-trigger input.
That's why the build those parts.
Otherwise you may get unsatisfactory/erratic behavior of the circuit.
karas
Joined Sep 8, 2011
216
Hi , i can not find SMT 3inputs or gate with a Schmitt-trigger input., do you know one?
ebp
Joined Feb 8, 2018
2,332
EDIT - these parts aren't suitable - they tolerate transitions slower than "normal" but aren't really appropriate for the application - the maximum rise and fall times are spec'd in nanoseconds per volt The description of them as having Schmitt trrigger inputs is rather deceptive (NXP datasheet; TI sheet makes no such mention).
74LVC1G332 - three input OR with Schmitt trigger, or if you rework the input circuit to be active low instead of active high, you can do task with a single 74LVC1G10 (applying DeMorgan's theorem).
Papabravo
Joined Feb 24, 2006
22,111
The original question wasn't about looking for an optimal part, but any collection candidate parts for further consideration. This exercise illustrates the real point of the thread, which is that a TS must evaluate all suggestions with respect to his original requirements which may or may not be explicitly revealed in the thread. In addition a good designer will read and thoroughly understand a datasheet when considering any part for use in in a product or a project.
