CMOS Crytsal oscillator vs regular crystal
Gibson486
Joined Jul 20, 2012
360
What is the difference between these two? Is a unit like the ASV-8.000MHZ-EJ-T just built a round an actual crystal? Is the difference that you simply have the hardware integrated vs needing your circuitry that is already in most micros?
Thanks!
MuPlusSigma
Joined May 22, 2014
15
A crystal is just the crystal. A crystal oscillator circuit is an oscillator circuit that includes such a crystal.
Yes, a unit like the ASV-8.000MHZ-EJ-T is built around an actual crystal.
Yes, an oscillator IC simply has the hardware necessary for an oscillator already integrated, versus whatever external circuitry would be used with a crystal, such as a microcontroller, or discrete components composing an oscillator.
RichardO
Joined May 4, 2013
2,270
The main advantage of a crystal oscillator over a crystal connected to a microcontroller is that it is a known commodity.
The oscillator manufacturer knows more about his crystal and oscillating circuit than you are likely to know about a crystal and microcontroller combination.
