I want to design a class-d amplifier using a LTC4449 n-mos gate driver on LTSpice. But there is a problem in output signal. It is not a perfect sinusoid. I realized that ,according to data sheet, the gate drivers output Bg is not at desired interval and also there is a cross conduction current issue. I tried using a Mosfet that has small input conductance but it didn't work.
If someone could give an advice, I will appreciate for
