With a 1k load the darlingtons have such a low current that they do not even get warm.
But with an 8 ohm load the darlingtons are passing a high current which causes them to heat which causes then to conduct more current from the positive supply to ground which causes them to heat more - more current - more heat - more current - more heat ..... blow up.
Why do you drive the darlingtons with three emitter-follower transistors in series? Emitter-followers don't have any voltage gain.
