Clarification with common collector...
WBahn
Joined Mar 31, 2012
33,221
I've been simulating with 40 Hz, could that be a problem?
Possibly. But it's easy to explore, isn't it. Increase the frequency to 400 Hz and then perhaps to 4 kHz and see if you see a significant difference. But also heed what #12 is telling you about discharging the coupling capacitor.
clickman
Joined Dec 9, 2016
28
My "aim" is to explore the use of this amp for audio applications, am I wrong by using it in this way?
#12
Joined Nov 30, 2010
18,224
I answered that in post #4
It has been done. It used to be the standard way to make a class A amplifier.
Who is going to tell you that you are wrong to do what has been done thousands of times before?
Now, if you want to put a modifier on that like, "good" or, "efficient" audio amplifier, you could receive a different answer.
clickman
Joined Dec 9, 2016
28
Sorry i completely forgot that it was answered.
When you say "good" or "efficient", that points to op amps? or should i still explore discrete transistors?
#12
Joined Nov 30, 2010
18,224
Explore them for what? You never said anything except, "audio amplifier". You can make audio amplifiers several ways.
If you want to name any particular property of an audio amplifier, like frequency range, distortion, or power efficiency, there will be something to talk about.
clickman
Joined Dec 9, 2016
28
well when i say explore them i mean understand deeper how they work, their properties and things like that. Remember that i'm a complete novice.
#12
Joined Nov 30, 2010
18,224
Class A is a great place to start. Then look at push-pull, then op-amp driven, then amplifiers that are essentially huge, discrete op-amps, then IC power audio amps, then fast switching audio amps. That's most of them.
clickman
Joined Dec 9, 2016
28
Interesting!
Playing around with this sim i'm using i saw a follower simple that it is biased at the center of the supply voltage at the base. where i "learned" it said that the base had to be 1/2 supply + 0.65 V. also this simple has a very Little (40 ohm) emitter resistor.
Could you give me a tip about biasing and about the emitter resistor?
#12
Joined Nov 30, 2010
18,224
If you're going to charge the output capacitor through an 8 ohm speaker, you need to discharge it through an 8 ohm emitter resistor.
(This isn't exactly true, but it's close enough for a beginner.)
38,834
Requiring such a low emitter resistor value is the reason such a Class A amp is seldom used to generate any significant amounts of power into a speaker.
clickman
Joined Dec 9, 2016
28
And looking the simulations a deep fried transistor too! I guess that's why class A are not chosen too much or have been displaced in favor of other classes.
WBahn
Joined Mar 31, 2012
33,221
It depends on the needs. For very good linearity it's hard to beat Class A, but it comes at a significant power cost. Remember that the reason there are different types of amplifiers is that they all have their pros and cons. If there was one, best, fits-all type, then that is all we would use. Engineering almost always comes down to compromises. So learn those pros and cons so that you can make reasonable and justifiable compromises -- your employers will love you.
clickman
Joined Dec 9, 2016
28
balance, balance & more balance...
AnalogKid
Joined Aug 1, 2013
12,280
that means that if i want to drive a 8 ohm i need a smaller emitter resistor?
Yes, and that rapidly can turn into a real design problem. The smaller the emitter resistor, the larger the transistor has to be and the more power it has to dissipate. This is why the "push-pull" output stage was invented.
Depends on what you want the circuit to do. For telephone-quality voice signals you can get away with a low frequency corner of 300 Hz, but for even low quality audio you want that corner below 100 Hz.
ak
clickman
Joined Dec 9, 2016
28
ak
I will definitely read about push pull.
BobTPH
Joined Jun 5, 2013
11,659
Your emitter resistor is way to large. When the transistor is off, this is the only path to ground for the speaker, so the negative half of the cycle is severely attenuated, giving you a very distorted output.
Change the emitter resistor to 8 Ohms and the output capacitor to 1000uF. According to my simulation, this gives you about 450mV on the output.
Bob
