ckt modification
maanas.adi
Joined Nov 3, 2011
12
hi all
i have been given a ckt to minimize the components required. i am attaching the ckt as pdf.
working:
the ckt is for operating a small dc motor. when sw1 is pressed it starts moving in left direction. after reaching the extreme left position, we get indication through No/NC contacts. the motor cannot be stopped in between. when in left position then only switch 2 will work.
i cannot use digital pulse based h-bridge or microcontroller. also another switch might be required to stop the motor in between and then change the direction.
thanks in advance
33,325
So.... what have YOU done to try to solve YOUR homework problem? You need to show an honest attempt that will serve as the starting point for a discussion.
